Viewing the WLANs Report from Wi-Fi
The WLANs Report page provides insights into SSID activity, client distribution, and traffic usage across WLANs. The page includes analytics for active SSIDs, client counts, traffic consumption, and SSID activity trends.
- Wi-Fi
To view the WLANs Report page from Wi-Fi main page, on the navigation bar, select .
To view the WLANs Report page from Business Insights main page, refer to WLAN Report.
- Overview tile
- Top SSIDs by Traffic tile
- Top SSIDs by Client Count tile
- Active SSIDs Trend tile
The data displayed is for the selected time period in the Date and Time filter.
Some of the tiles have the option to view the report in graphs and tables. The Graph and Table tabs are displayed on top of the applicable tiles. By default, in those tiles, the reports are displayed in graphical format. If you want to view the report in table format, click the Table tab.
The data displayed on this page is based on the selected Date and Time filter and Network Hierarchy filter. Use the Date and Time filter in the upper-right corner to select a predefined time range or configure a custom date and time range. Use the Network Hierarchy filter to refine the displayed data by network scope.
The top right corner of the page also displays options to download reports in PDF and PNG formats. You can also share the report via e-mails on-demand or periodically by configuring a schedule (daily, weekly, or monthly).
All of the tiles described above are explained in detail on the WLANs Report page under the Reports section. Refer to WLAN Report.
