Adding and Managing a Custom Role
You can create custom roles to control administrator access at a granular level using role-based access control (RBAC). Custom roles allow you to define precise permissions and scopes, such as Read Only (default), Create, Edit, or Delete, across technology categories. This helps organizations enforce least-privilege access and delegate responsibilities effectively. By default, system-defined roles are also available for assignment to administrators.
For more information, refer to the various administrator roles at Understanding Administrator Roles and Privileges.
Before creating a custom role, review RBAC and ABAC Support to understand how roles, users, and groups (SSO or privilege groups) interact.
Create a custom role as follows:
  1. Click Manage My Account to go to the tenant portal for your own account.
    You can access Manage My Account from the top right corner of most MSP portal pages.
    The RUCKUS One web interface is displayed.
  2. On the navigation bar, select Administration > Account Management > Users & Privileges.
  3. Click the Roles sub-tab.
    The following information is displayed:
    • Name: Displays the name of the role.
    • Description: Displays a description of the role.
    • Role Type: Displays whether the role is system-defined or custom. System-defined roles are pre-configured and cannot be modified. Custom roles are user-defined and editable (depending on assigned privileges).
  4. Click Add Role.
    The Add Admin Role page is displayed.
  5. In the General section, type the role name and a short description for the role.
    Note: You cannot create a custom role with the same name as a system-defined role.
  6. Click Next.
    The Permissions page is displayed with two types of permissions.
    • Global Permissions apply broadly across the system.
    • Advanced Permissions provide more granular, scope-based controls.
    The permission categories in each tab mirror the sections of the main navigation menu on the left side of the RUCKUS One web interface, helping administrators align access control with functional areas of the application.
  7. (Optional) In the Global Permissions tab, assign permissions for the following high-level categories:
    • Wi-Fi
    • Wired
    • Gateways
    • AI
    • Admin
    • MSP
    Note: The MSP functionality is visible only to MSP admins, allowing them to configure granular access control for MSP-EC tenants.
    For each category, you can apply the following permissions:
    • Read Only (set by default): Allows the user to only view items.
    • Create: Allows the user to create a new item.
    • Edit: Allows the user to configure an existing item.
    • Delete: Allows the user to delete an item.
    Custom Role: Global Permissions for Device Management
  8. (Optional) Select the Advanced Permissions tab to manage role permissions for specific features and functionalities within each category. By default, the Wi-Fi sub-tab is displayed. To configure granular access controls, complete the following steps:
    1. Click a category sub-tab (for example, Wi-Fi) to access specific functionalities.
    2. Click the icon to view and configure individual features within a functional area (for example, Venue).
    Custom Role: Advanced Permissions for Device Management
    Note: Default selections in the Advanced Permissions tab depend on the choices made in the Global Permissions tab, but can be changed. Permissions set in the Advanced Permissions tab override those set at the global level.
    Note: If you see a hyphen () instead of a checkmark () for a specific category action (Create, Edit, or Delete), that means the permission for that action is not granted uniformly at the advanced level for that category. You may click the hyphen to grant global permission, but this may still result in partial inheritance of permissions at the Advanced Permissions level. RUCKUS recommends checking the advanced permissions for the category and modifying as necessary.
    Refer to Management Scope for Permissions for details on supported and unsupported functionality scopes.
    By default, Read Only access is assigned to each functionality if no permissions are set at the global or advanced level.
  9. Click Next.
    The Summary page is displayed, providing details about the administrator role and permissions. Verify this information.
  10. Click Add.
    The newly created custom role is added to the list of roles in the Roles sub-tab. A notification is displayed on the Activities page, accessible from the icon at the top right corner of the RUCKUS One web interface.
    You can edit and delete custom roles by selecting the role and clicking Edit or Delete, respectively. You cannot edit or delete system-defined roles. A notification appears on the Activities page whenever a role is edited or deleted.
